First post, by DevilMan
Hi, ALL!
Here another question about good ol' Blood! 😀
I can't start network game - setup crashes with message (something about netbios). I have integrated ethernet card on my nForce2 motherboard (Epox 8rda+). Maybe, problem with this?
hey ho let's go
Reply 1 of 4, by kriztofo
I believe that error appears when the IPX network protocol is not installed. Just add a new protocol in Network properties and choose IPX. If you are running XP i don't think you even need to put the windows cd in, but on others you need it I think.
Reply 3 of 4, by kriztofo
If you are running vdmsound do you have the "Low level network support" option checked in the blood setup shortcut? If I'm not mistaken I needed it checked to play network games with blood.
