First post, by Vikingo
Hello everyone. I'm new to the forum and I'm still putting together my retro PC. Meanwhile, I'm trying to see how to do certain things.
I would like to know if there is any way to install a bootable DOS on an external hard drive using a modern computer with Windows 10 or even a Mac. If I get a positive answer for this I will save myself dealing with diskettes that are not easy to get where I am.
Thanks
Follow me on twitter @cristian. 🤣
Reply 1 of 7, by squiggly
External as in USB? Assuming BIOS can load and boot a DOS boot sector from a USB hard drive...wouldn't DOS itself need USB support to see the disk it is booting from? Which it doesn't have AFAIK.
Reply 2 of 7, by Vikingo
My idea is to format and drive and try to install DOS in my actual PC and later put that disk into the retro PC.
I can copy files into the old HDD, no problem with that. Just wondering if i can in any way install DOS into that drive using my actual PC. Have no floppy drive, only the DOS images.
Reply 3 of 7, by gdjacobs
I've done this using a VM and a pass through device file. Although I use KVM now, you might find VirtualBox to be more convenient. Here's how you set it up.
https://www.serverwatch.com/server-tutorials/ … tualbox-vm.html
I installed DOS 6.22, Win 3.1, and lots of other stuff with virtual floppies this way. The only downside (and one of the reasons I use KVM now) is that VBox is less flexible when it comes to floppy formats, but it's still a very handy trick.
Reply 4 of 7, by Vikingo
Thanks!!! This look like what im looking for. I need to test if it work with the hard drive conected vía USB.
Reply 5 of 7, by gdjacobs
That's how I used it. Let me know if you have trouble.
Reply 6 of 7, by Vikingo
I succesfully installed MS-DOS 6.22 into the external hard drive. Have several permission problems while i try create and later mount the vmdk file. Solved everything with this fantastic GUI tool for OSX. https://whatroute.net/vboxrawdisk.html
