Cannon Fodder with Roland MT32
Getting old DOS games working on modern hardware. (DOSBox topics belong in DOSBox areas below, not here).
Postby paulo_becas » 2018-10-18 @ 15:07
I've been trying this for a while and can't get it to work.
Does anyone ever manage to get cannon fodder to work on your DOS PC with the MT32?
It crashes the computer every time.
AMD Am486/Am5x86-P75 DX5 133 Mhz-64Mb Ram
S3 Trio 64V2DX 2 Mb
Soundblaster AWE64 Gold+Music Quest+Roland MT-32
LAN-3Com EtherLink
1.44 3,5 Epson Drive+1.2 5,25 Mitsumi drive+Iomega Zip 256Mb
8gb HDD
4Gb CF HDD
HP CDRW 9200
http://jp-retro.blogspot.com
User avatar
paulo_becas
Re: Cannon Fodder with Roland MT32
Postby ripsaw8080 » 2018-10-18 @ 15:57
The MT-32 music in Cannon Fodder does not work in DOSBox when cycles are too high; e.g. the music works at 8000 cycles but not at 10000 cycles. So, on a real system you may need to slow things down: turn off turbo mode (if applicable), disable CPU cache, use slowdown utilities, etc.
User avatar
ripsaw8080
DOSBox Author
Postby paulo_becas » 2018-10-18 @ 16:09
If i slow down the computer will the game still works well or does it slow down too?
S3 Trio 64V2DX 2 Mb
LAN-3Com EtherLink
8gb HDD
4Gb CF HDD
HP CDRW 9200
User avatar
paulo_becas
Postby ripsaw8080 » 2018-10-18 @ 16:18
Minimum processor requirement for Cannon Fodder is 20 MHz 386SX, so just be careful not to go below that level of speed.
User avatar
ripsaw8080
DOSBox Author
Return to DOS
Who is online
Users browsing this forum: No registered users and 3 guests
