yeah I know, Wipeout XL/2097 is a whole other can of worms. An unthrottled piece of poor programming! Odd given that Psygnosis released it around the same time as Formula 1 (95) which can still be coaxed into working in Windows XP, whereas Wipeout XL runs at a million frames per second!
Actually in Wipeout XL you can see the frame rate by typing FRAMERATE when on the menu screen. Doesn't help slow it down though!
Incidentally Wipeout XL cannot be slowed down on hyperthreaded PCs by using slowdown applications as they only slowdown one thread! The best bet is to get the PlayStation version (which has better music!) and use a PSX emulator. Or get Wip3out Special Edition which is better still (I never got Wip3out (non-special edition) to work properly in any PSX emulator. Anyway I'm rambling now, go try those DOS games and see if you have the same problem!
Ice
