Screamer dos and gravis ultrasound music.
Getting old DOS games working on modern hardware. (DOSBox topics belong in DOSBox areas below, not here).
Postby pngo » 2018-11-17 @ 14:52
Hello.
I am trying to get music working in Screamer dos with a gravis ultrasound classic upgraded to 1mo.
The setup lets me select the gus for sound effects and it works fine but the music shows port 388 which cant be modified and music test does not work.
What does this port 388 relates to? There does not seem to be any configuration for the gus that involves port 388.
Is there any required tsr to have music in this game like sbos/megaem/ultramid?
If i save and run the game with this music configuration i get a "cannont initialiwe sound driver"error.
pngo
Re: Screamer dos and gravis ultrasound music.
Postby jesolo » 2018-11-17 @ 16:30
Port 388h refers to the standard Adlib port for FM synthesis.
Since a GUS does not have an OPL2 or OPL3 FM synthesis chip, it is emulated in software.
Since that is the only port being listed in the setup program, my guess is that there probably isn't direct GUS support. You either have to load SBOS or MegaEm for Adlib/Sound Blaster support.
However, I haven't tried playing Screamer on my GUS PnP Pro yet, so maybe someone else here that has played Screamer with a GUS can provide more insight.
User avatar
jesolo
Postby pngo » 2018-11-17 @ 22:08
MEGAEM is probably required then. Too bad its not loading because of the emm386 problem i have on my machine that has too much ram.
pngo
Postby mrau » 2018-11-18 @ 15:39
use a different driver for xms/ems
mrau
Postby realnc » 2018-11-18 @ 16:07
Yes, you should try something like QEMM 97, which replaces both emm386.exe and himem.sys and can deal with large amounts or RAM.
User avatar
realnc
Return to DOS
Who is online
Users browsing this forum: tokyoracer and 1 guest
