First post, by mamelone
I can run GK 1 under windows XP compatibility mode by setting the display to 256 color and 460x680 but when I try to save a gave everything goes black and the system hangs. No error message, nothing. Is there a way to save games? I installed the windows version on a 1ghz system running Windows XP. Are there any work arounds to save games?
Marsha in So. Calif.
Reply 3 of 4, by mamelone
OK, I guess I will take the plunge into DOSBox. It looks pretty complicated but there seems to be a lot of info here. Away I go! I assume I will be abel to restore without any problems with dosbox. Right?
