First post, by Sandor
Hello;
I'm trying to get the game 7th Guest working but... I'm not even eble to install the game because the installation keeps hanging on the choice of my soundcard (i bought a brandnew SB 5.1 live to keep my ' beloved' computer happy, but whatever the installation is aborted....
I haven't been able to actually install the game, let alone run it via DOSBox. Is there a way to install the game using settings i give in the dosbox config ??
With regards,
Sandor
Reply 2 of 9, by Snover
Running The 7th Guest & The 11th Hour in non-Real DOS is really hit-or-miss. You could have too much diskspace or something... without system specs your request is USELESS!
Yes, it’s my fault.
Reply 3 of 9, by Dr. Riptide
If you have Windows with DirectX, you can probably use the native Windows version of the game. You can get the Windows patch here: http://dlh.net/getfile.php?40:/pc-patches/gen … ches/t7gwin.zip
Note that this thing never left beta, and tends to crash randomly, so you need to save often.
You might also try VDMSound.
Intel Q6600 (2.4 GHz) | 4GB RAM | GeForce 8800 GT | Windows 7 64-bit
Reply 4 of 9, by Sandor
Dear people,
I'm trying to keep up with your responses, ..... but i can't !!
I'm not an expert with computers (but not a layman either) but i'm stuck with the installation: I have a SB 5.1 Live installed, but the game just keeps telling me i have selected the wrong settings and won't complete the installation. How can i use dosbox to fool the game i do have the correct requirements??
If someone has an answer to this question i would seriously be MOST obliged !!!! My sb-card has according to my computer the following settings: Location 4 (PCI bus 0, device 14, function 0).
What can i do ???
With regards,
Sandor Singer
Reply 5 of 9, by priestlyboy
I happen to have the official Windows Version and the DOS Version of the 7th Guest.
I perfered the DOS Version though.
7th Guest (DOS Version) is runnable through DOSBox a'la this forum.
Ieremiou
Helping Debug DOSBox.
Reply 6 of 9, by Sandor
Hazakel & Prieslyboy: How can i run it ????
I'm no connaiseur when it comes to computers; All i want to do is install the fr**ging game and play it.... but i can't bleeeeehh;
The problem is...i haven't very much of a clue as to how to succesfully use dosbox
Any tips or sugestions would be very helpfull...
With regards,
Sandor
Reply 7 of 9, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
See DOSBOX Guides forum. There is a newbie guide with images.
Mirek
Reply 8 of 9, by Hazekel
Assuming E: is your CD-Rom try the following:
mount c c:\
mount e e:\ -t cdrom
after this is done, switch to e:
e:\
then run the install program. DOSBOX has its own configuration for the Soundblaster so it may not match your own. I don't remember its exact settings, but I think they are 220 7 1 or maybe 220 5 1
If this is successful, then do not exit DOSBOX. Try to execute the program through DOSBOX and see how that works.
Reply 9 of 9, by mammlouk
I am running dosbox under linux and have succesfully installed 7th guest. I am having a problem getting the game to recognize the CD. I am mounting my drive as follows:
mount d /mnt/cdrom -t cdrom -usecd 0
I have also tried copying the CD to a directory and mounting the directory as the CDrom but have had no success. 7G just keeps asking me to insert disk1. Any and all help is greatly appreciated.
Thanks,
Jeremy
