First post, by mike82
hi guys...before to explain my problem i excuse me for my english...-not very good!
i have problems to excute dos games like aladdin or world class leadeboard...:the first, under win98se ,doesn't start and under dos the system says "xms allocation error"; the second doesn't start under win and starts under dos but the audio is not very good...which are the solutions?
p.s. i don't want use emulators..but resolve the problem under win98se or dos!
p.s.s excuse me..but maybe i've chosen the section wrong and i've rewritten the message!
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
xms allocation error with alladin. I recall from dosbox that it happens if you have too much xms memory. So try limiting it ? properties and then memory tab or so ? Dunno been a while
Water flows down the stream
