7th Guest Dos version
Getting old DOS games working on modern hardware. (DOSBox topics belong in DOSBox areas below, not here).
Postby dp1983 » 2019-8-05 @ 13:29
Hi,
I'm trying to get 7th Guest working in DOS. I have a feeling its a sound related problem. I'm using a laptop which has a ESS Maestro 2E sound chip, got the dos drivers loaded and works fine with other games. When I load the game it will play the first couple of notes, CD spins up and it will crash, black screen and nothing happens, I have to restart to clear it. The game detects the sound chip as a Sound Blaster pro 2, I've tried different options but the same issue
Any suggestions,
Dan
dp1983
Re: 7th Guest Dos version
Postby collector » 2019-8-05 @ 14:21
Ask old hardware and driver/configuration questions in Marvin. viewforum.php?f=60 This forum is for DOS games on *modern* systems.
User avatar
collector
Return to DOS
Who is online
Users browsing this forum: Tommybrownbear and 3 guests
