Can you install command.com or 16 bit drivers on Windows 10?
Getting old DOS games working on modern hardware. (DOSBox topics belong in DOSBox areas below, not here).
Postby twiz11 » 2019-8-22 @ 19:40
To run legacy dos apps without dosbox?
twiz11
Re: Can you install command.com or 16 bit drivers on Windows 10?
Postby ShovelKnight » 2019-8-22 @ 19:41
No, it's impossible.
ShovelKnight
Postby AlaricD » 2019-8-22 @ 20:31
In the 32-bit version you can install the optional feature "NTVDM", then use fondue.exe to enable it. In the 64-bit version, no.
You could always use Hyper-V and create a generation 1 virtual machine and install MS-DOS there.
User avatar
AlaricD
Postby schmatzler » 2019-8-25 @ 19:47
Well, there is NTVDMx64. It is based on leaked source code of the original NTVDM.
http://www.columbia.edu/~em36/ntvdmx64.html
schmatzler
Postby Jo22 » 2019-8-26 @ 13:23
There's also MS-DOS Player, which can run DOS programs off the command line.
Once installed in a directory that is in the path= variable, someone just has to type "msdos yourapp.exe".
http://takeda-toshiya.my.coocan.jp/msdos/
User avatar
Jo22
Postby rswill » 2019-9-01 @ 05:03
Jo22 wrote:There's also MS-DOS Player, which can run DOS programs off the command line.
Looking the same, I have 64bit of windows 10 and haven't found any solution for it, I will try this after my vacation hope it works :) thanks
rswill
Return to DOS
Who is online
Users browsing this forum: No registered users and 3 guests
