First post, by kolderman
DOS produces quite a lot of output on startup (drivers, emm386, etc), is there a way to log all this output to a file?
Autoexec.bat is easy to output the output to a file.. not sure if it works with config.sys though as I've never tried it.
See here:
https://www.robvanderwoude.com/battech_redirection.php
And instead of ">" to output to a new file, use ">>" to append to a new or existing file.
