First post, by Geofferic
After reading gobs of posts on this and other forums, I believe that the inherent problem I'm having running SimHealth is that Phar Lap is not a very fun extender.
Errors I get: In WXP I get error 286.2360 : Out of interrupt stacks.
It doesn't seem to matter what I set the stacks variable to in the config.nt file, this error persists. It is my understanding that stacks is kinda bogus in XP, but I'm not real clear on this.
I then tried running it in DOSBox, but I get a different error: 286.3330 : Segment not present fault detected.
I have no idea what that error is about.
In the WXP native environment, the 286.2360 error typically won't show up until I hit the enter key somewhere or try to play a script in the game. (The script is this thing telling you all about a health program you could implement).
Anyone have any ideas? Should I just give up on this?
Thanks!
Earnest
Reply 1 of 1, by Geofferic
Gah, forgot to include some info.
0.63 DOSBox
P4 2.4 gHz on a Titan mobo.
gig of ram
I am using the on board sound, but the problem occurs even with the sound turned off. (IE, no sound selected via the setup program.)
128 meg GeForce Ti 4200.
WXP SP2
