First post, by madgitty
Having problems trying to get the collectors cd of tie fighter to play, have a. S3 card but will not run in svga,
Any ideas
Thanks
Reply 1 of 2, by kjliew
Depend on the date/make/model of S3 cards, some may not have updated VBE 2.0 support for SVGA games. If this is the issue, then you can run a TSR called UNIVBE to fix it. Most SVGA games should have bundled a copy of OEM customized version of UNIVBE with the installation media.
