First post, by rtg7
So you think it will?
I downloaded CPU Killer by the way, it kicks ass
slows down ur computer to any speed
anyways, im pumped cause i got this game coming, but i was just wondering if it will run in virtual dos?
Reply 3 of 3, by Nicht Sehr Gut
I've yet to hear of someone running it within Windows due to the memory methods used by Origin (I believe that Strike Commander uses VCPI memory like "System Shock" and "Wing Commander: Armada"). If not, you can try hacking your WinME to access "true" DOS again.
Word-of warning: The three patches are "at-your-own-risk" hacks that work for most people but have no guarantees. Use only if you're fairly knowledgeable about DOS/Windows.
http://members.aol.com/axcel216/dos.htm#ME
(They are all labeled as "Unofficial Windows ME" patches)
