First post, by MissMix
- Newbie
Since I started to have problems with a few DOS games (problems I didn't have before while nothing crucial has changed, oddly enough), a friend recommended installing DOSbox. It didn't work at first, and now I've downloaded the newer version 0.63 (as opposed to 0.60) to see if that worked.
Nada.
I first did as I was told and copied the .exe file from the game, which I then pasted over the dosbox.exe file. Didn't work. Then I double-clicked dosbox.exe directly, but that didn't work either.
What happens, is that I see a DOS window pop up called DOSBOX. So far so good. Another window pops up, which remains blank (or rather, black). I click on the DOSBOX one to get it on top and see it "failed to create a rendering output".
I looked at previous threads with the same problem, and tried editing the output factor in dosbox.conf. Overlay and ddraw do nothing, but with opengl and openglnb, I get an extra line in the error message:
SDL:OPENGL:No support for texturesize 1024, falling back to surface.
Right. That didn't work.
I checked, and I have only 1 version of sdl.dll.
My system data:
Motherboard: Chaintech 6VIA3 S370 (nano symbol)ATX Mainboard
Processor type and speed: Celeron 566 Mhz (Socket 370 128 Kb Pr)
Amount and type of RAM: 256 Mb Bits 133 Mhz SDram
Video board w/ RAM amount and type: 8 Mb S3 AGP Video card
Sound board: "on-board integrated sound card"
Operating system: WIN 98SE
Sound mode used: what's sound mode?
Video mode (Software, OpenGL, Direct3D, or Glide, and resolution): euh... I installed a cd-rom with software from Diamond to get the resolution and stuff right, is that it?
Version of emulator (for VDMSound, probably 2.0.4 or 2.1.0; for DOSBox, 0.58+): DOSbox 0.63
DirectX version: 9.0c
I'm getting rather desperate, can any of you please help me? I'd really like to try out Eye of the Beholder, and ever since Pinball Fantasies stopped working (the game I mentioned earlier, which used to work perfectly fine on my comp - wait, except for the sound that is) I've been missing that game.
I'm out of options. :'(
