First post, by The Jackyl
I've tried searchin around for answers to my problem but have so far found none.
From what I understand DosBox v0.63 is suppose to include VESA support however when I try to run the game I get an error stating that it "Could not initialize VESA 15 bit 640x480 mode." I've tried to go through thedosbox config file and I an unable to find any setting for VESA.
On another note I've also tried using a regular dos shell plus SolVBE. The game starts to run but shuts down with the error that it cannot initiate sound even when I've set the sound to none.
Also DosBox doesn't seem to like SolVBE as if I try to run SolVBE from DosBox it causes DosBox to just close.
Any suggestions?
