First post, by kukus444
How do i get sound (real sound, and music <if there is)on
ultima 6????please help me with this....because i have sound on all the other ultima games without ultima 1 2 and 6....its because of thet, i need sound to ultima 6.....i beg you...please help me with this.......
//Kristofer (sweden)
- Kukus444 has spoken!
Reply 3 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
for music you have to choose the sound device in the install of Ultima6.
For sound effects you are screwed as ultima6 only uses pc-speakers. Only workaround is to use Dosbox.
Why doesn't Vlad implement pc-speaker emulation in Vdms? (I know he stated his reasons ages ago but I forgot).
Reply 4 of 5, by Nicht Sehr Gut
Originally posted by Dominus Why doesn't Vlad implement pc-speaker emulation in Vdms?
For the same reason you don't put a steam engine in a 1966 Mustang. VDMSound is a soundcard emulator. Using a PC speaker for sound is nothing like using a soundcard. Basically, he would have to write a separate program just for speaker audio.
Since Ultima 6 runs insanely fast on modern PC's, the best bet is to use DosBox, choose AdLib audio, and use it's ability to slow down the program to just a few cycles.
