First post, by Alfredo 58
Just got a copy of Elite Plus after I found I couldnt load or save in Elite original. My next problem is what filename should I ask DOSBOX to use when using the cd command? Up till now when I use "cd Elite plus " or variations on this I get "unable to change to.... whatever i have used or whatever syntax. Seriously frustrating. Anyone out there got an answer? I'm using oldgames as my main directory which is mounted ok and I got the C prompt. All this worked fine with original Elite except as I say it wouldnt Load save.
Reply 1 of 2, by MiniMax
Rank Moderator
Moderator
Try
C:
dir
It should point you in the right direction.
_________________
