First post, by 9646gt
So I have the GOG version of Tyrian 2000. I am trying to use it natively and not the built.in dosbox option from within Windows ME (I'll install 98SE when new HDD arrives). I launch the setup program but the various DMA options even complain they can't find a sound blaster compatible card or worse completely lock the system up. I believe DMA 0,1,3 are the options.
I have the default Win ME drivers installed for the sound card which is an ESS 1869. It shows in device manager as ESS 1869 Plug and Play Audio Drive WDM. It's installed on the only ISA slow of my Dell XPS t550 machine with the BX440 MOTHERBOARD, 512mb RAM, and Pentium III 550. This is a fresh OS install with no autoexec or config .sys changes by me. The card has the following resources showing in windows IRQ 7 (I reserved it in BIOS since I heard some older games prefer 7 to 5), the first DMA says 1 and the second says 3 IO 0240-024F 0388-038b 0300-0301
