First post, by Wickhmar
Hi there,
I'm having problems getting Tie Fighter to run. It keeps asking me to set files=40 when I try it with Dosbox or VDMS. I've edited my config.nt in the system directory to include the files argument, but it still comes up with the same error message.
I'm running XP SP None.
Any ideas?
If it ain't broke, fix it till it is.
Reply 2 of 6, by HunterZ
Did you get it working then? Was it putting it in a dummy c:\config.sys that fixed it, or what? Might help others in the future to know how you solved it (if you did).
Reply 3 of 6, by Wickhmar
Sure,
Well, according to the link it turns out that there's no subfolder hierarchy in the Tie Fighter zip file. Luckily, I had X-Wing Vs. Tie Fighter installed on my machine and I was able to recreate the different subfolders based on that.
Once I had the game running, it would crash when looking for specific files. I would then get the particular files the error message mentioned, create the subfolder in question and simply cut and paste.
The subfolders are as follows: CP, RESOURCE, SOUND, MISSION, FRONTRES and IVFILES.
((Keep in mind that some of these folders might not be needed as they relate only to XvsTie. I've also duplicated a large number of the files to be on the safe side))
The MISSION folder contains the *.TIE files
FRONTRES and IVFILES contain the *.LST files (I'm not sure the IVFILES folder is needed at all...)
For the RESOURCE subfolder I copied the entire root into it.
SOUND contains the *.ENG, *.WDR and TESTMIDI and TESTWAVE
And CP contains the *.INT, *.LFD and *.PNL files.
Tada!
Reply 4 of 6, by HunterZ
That's interesting. I remember having the same thing happen to me once when I used a ZIP-file splitter on an X-Wing floppy version backup I was trying to install from once. I ended up doing the same thing - move a file into the correct subdirectory whenever it crashed due to not being able to find it there.
Reply 6 of 6, by Wickhmar
Then it's a good thing I popped everything into the Resource folder. To be honest, SOUND was just an (mis?)educated guess. If I have time, I might systematically delete files to find the exact subfolder configuration but I wouldn't hold my breath! 😀
