First post, by claustho
Hi.
I have just installed Strike Commander, and I have a problem with some keys in the game.
Almost all keys works perfect, but I can't use the numbers 1,2...0. They are used for controlling the engine power. No matter what key I press the engine power just sets at 2.
It makes the game unplayable.
Does anyone have an idea what the problem could be?
I also had a problem installing the game. I could not swap the floppydisk. When the installprogram asked for disk number 2 it would not accept disk number 2. I have installed DOS 6.22 on one of my harddrives, so I booted from that disk and installed the game from there. I do not now if this could be the reason for the problem. For example with codepage or something...
Reply 1 of 4, by Zup
Bad crack. Yes, it is a bad crack. Go find another crack and apply it.
I'm selling some stuff!
Reply 3 of 4, by Kippesoep
Do the numbers work correctly on the DOSBox command prompt? If not, they've probably been remapped. Remove the mapper.txt file from your DOSBox directory.
Reply 4 of 4, by eL_PuSHeR
claustho wrote:
The game that I have is not a crack. It is the original game, but I will try to find the game on the net and download it.
Can anyone recommend a page where it can be downloaded?
NO
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
