First post, by mg886112
My English is poor,so I hope the answer could be easy understand.
I am a Chinese gamer.When I was playing some Chinese games,I
found that the caption(or words? I don't know. My English is poor.)
in the game is broken or disappeared. Ah...that's a big problem.
I couldn't know what characters is talking about. Hmm...would you
help solve this problem? Maybe there is a patch could repair this?
Thank you.Hope the problem could be solved.
By Jacket Kuo
Reply 2 of 10, by mg886112
The newest is 0.63,right?
The game name is Chinese. It called 同級生2.
Hmm...I am just afraid that no one understand it......
My English is poor.So if I have published some impolite word or
wrong grammer.Please forgive me.
Thank you. By JacketKuo
Reply 3 of 10, by ykhwong
我知道 '同级生(tong/ji/sheng) 2' (in korean, the pronunciation is dong-geub-seng).
I searched for it in my site, but it seems the game doesn't work in official version.
I tested it in cvs build, but it also does not work yet.
Reply 4 of 10, by mg886112
It's could be run in dos box. But there are some item need modifying.
It's complicated....I think I need using Chinese to express it.
Ah...that's ok? Would you accept?
Thank you. BY JacketKuo
Reply 5 of 10, by ykhwong
According to Judel, DOSBox, VDMSound, and QEMU doesn't support the game 同级生, but you can play the game under real-dos.
You may write here in chinese and I can read if you want. but my chinese grammer is poor 😀
Reply 6 of 10, by mg886112
OKay...
需要把資料夾底下的.bat .com .exe
按右鍵-內容後
把相容性改成適應98(or95)
如果有"記憶體"這個標籤
則把標籤底下所有選項改成自動
然後
DOSBOX的部份,可能需要把音效那邊的設定
調成支援OPL3
irq值5或是7都試試看
Hmm...hope you could understand it.
If there are some words or grammer that could not grasp it,
please replied and I will try my best to translate for you.
Reply 7 of 10, by ykhwong
你现在不用‘简体字‘。不可了解文章的部分。
我也改了DOSBox的很多[設定]。(OPL2/OPL3 等等)
那游戏是DOS用的。可是我不可以开始进行游戏。
所以你不必要下的
按右鍵(right click)->内容(go to properties)->把相容性改成適應(change to win98/win95 in compatibility)
- Windows XP 没有 DOS。有NTVDM (假想电脑)。
我想你要启动电脑(里 real-dos)
如果你想听游戏的音,你要古时的声霸卡和声霸卡的driver。
Reply 9 of 10, by ykhwong
no... if you're using windows xp, then you can't go to dos mode by pressing F8, because I had already said to you that WinXP has no DOS.
Create a bootdisk (diskette) that includes MS-DOS 5.x or 6.x with a utility, and boot it from the bootdisk. Then you can play the game.
