First post, by Rodney Betters
I've installed Doom 3 (with patch 1.1) on a Core 2 Quad, GTX 580, 4GB RAM, Windows XP machine and I've run into two major issues:
- I cannot enable the 'Ultra' quality setting. It seems as though the game cannot detect my graphics card and is defaulting to low settings. I figure I can make a config file with the settings required for 'Ultra' but I can't find any comprehensive list of which settings actually are part of the 'Ultra' setting. I want to be sure I'm not missing anything. Anybody know of a way around this without using an autoexec?
- Microstutter. I'm running the game with vsync enabled, capped at 60fps, but there is a stutter that occurs consistently every second or so. Any way to fix this without screwing up the game's timing/audio/physics?
Reply 2 of 13, by Rodney Betters
RandomStranger wrote on 2022-08-09, 05:58:
Thanks, that did the trick for the Ultra quality settings. Now all that's left is the micro stutter. According to the wiki, the easiest way to elimate the stutter is to remove the FPS cap by using the command 'com_fixedTic 1'. This does appear to fix the stutter but it introduces timing issues where the audio and video go out of sync. Tried different combinations of capped framerate/uncapped, vsync/no vsync, double buffering/triple buffering but all combos either have the microstutter or the timing issue. Am I missing anything?
Reply 3 of 13, by Rodney Betters
After some more research and testing, I've come to the conclusion that is not possible to have both smooth gameplay and physics/audio in sync. It's either one or the other as all "fixes" for the stutter put the audio/physics out of sync. Apparently, this affects all Id Tech 4 games (Quake 4, Prey, etc.). It's a bit disappointing, but considering this issue is inherent with the game, I'm not going to worry about it.
Worth mentioning that I was getting performance issues with 8xAA + forced 8x Transparency AA in combination with the in-game vsync setting. Simply forcing Triple Buffering in the Nvidia control panel solved the performance hit from the 8x transparency AA.
Reply 4 of 13, by MrEWhite
Rodney Betters wrote on 2022-08-10, 17:03:
This can be fixed by having a VRR monitor though.
Reply 5 of 13, by Rodney Betters
MrEWhite wrote on 2022-08-10, 23:04:
That would fix the stutter, sure, but wouldn't you still run into the timing issues (audio being out of sync)? I'm on a CRT monitor and not even setting the refresh rate to 63Hz will prevent the syncing problem.
Reply 6 of 13, by DosFreak
Have you tried any of the ports?
dhewm3_1.5.1pre1_win32 works but you'll need to change major and minor OS to 4 and 0 in the executable using cff explorer. I would attach it but defender complains and I don't feel like jumping through hoops right now.
fhDOOM-1.5.2-1414 also works
Ultimate Quake Engine is another option.
I haven't tried RBDOOM on XP yet but that's for BFG.
Make your games work offline
Reply 7 of 13, by Rodney Betters
I haven't tried any ports yet - I'll start looking into it. Though, I did read on PCGamingWiki that the timing issues are still present using dhewm.
Reply 8 of 13, by MrEWhite
Rodney Betters wrote on 2022-08-11, 00:04:
No you wouldn't, as it's 100% in sync with the engine.
Reply 9 of 13, by auron
why 63hz? sources like the old tweakguides page state the game's ticrate is capped to 60fps.
as far as i remember the game played fine with a 60fps cap in afterburner/RTSS, i don't know what version of that will still run on XP though. internal framecaps or even just vsync are usually a lot less precise than capping via RTSS.
Reply 10 of 13, by Rodney Betters
auron wrote on 2022-08-11, 15:34:
63Hz because the Doom 3 is actually capped at 62.5fps. I do have an XP version of RTSS handy. I'll give that a shot later today.
Reply 11 of 13, by MrEWhite
The game's tick rate is 62.5 Hz, not 60.
Reply 12 of 13, by lafoxxx
Not sure where else to ask, but I've always wondered
Why do automatic weapons (smg, chaingun, plasma rifle) in the game fire like this:
TaTaTaTaTa! TaTaTaTaTa! Ta! TaTa! Ta! TaTaTaTaTa!
instead of
TaTaTaTaTaTaTaTaTaTaTaTaTaTaTaTaTaTaTaTaTa!
Anything to do with the tickrate?
Reply 13 of 13, by Rodney Betters
I don't think so. I believe that's to make the weapons sound less monotonous.
