486 emulator
First post, by BladeTurbo
HI All,
I was wondering if there was a 486 emulator which runs under windows. i have tried a couple different dos ones, but i could not get them working. i have tried bochs and emu486 with no success.
thanks
Brad
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
Well bochs should work although it's known the hard to set up.
You could try virtual pc or vmware.
Both are not free but I think they work fine.
Is there any special reason why it should be a 486 ?
Qbix
Water flows down the stream
Reply 2 of 3, by BladeTurbo
i'm not sure if you remember, but Geoworks once had an OS called Geoworks Ensemble (which ran on top of windows). it was a really cool program, but it won't run on anything higher than a 486 (tried a pentium, but would not run). i once had a 486 machine but it took a dump on me (i'm still in the market for one as we speak). also, running older dos games is a pain in the ass. i tried virtual pc, but it emulates a pentium class or higher. Virtual pc is cool in that i was able to load windows 3.11 😀 I havent tried VMware, i'll download it and try it.
thanks for any help
Brad
Reply 3 of 3, by Nicht Sehr Gut
Originally posted by BladeTurbo i once had a 486 machine but it took a dump on me...
*gags from visual*
VPC is rather poor for most DOS games (the less audio/visual action the better), VMWare is worse.
