First post, by Perotin
If I'm not wrong, it was introduced in DosBox (and its forks) more than ~10 years ago and it's based on Aaron Giles implementation that he had done for MAME long ago. Voodoo cards are in pcemu for few years already. I'm just curious, what is/are the reason(s) for it still working very slow or simply unreliable in most cases (crashes, screen tearing, artifacts etc.)?
1) There's no knowledgeable person with a will to improve it?
2) Is the amount of work required too much so it's too risky to invest time and effort?
3) Technical difficulties are very hard or impossible to overcome?
4) Modern computer's limitations? Which one - CPU or graphic cards?
5) Lack of documentation?
6) There's simply not enough interest in 3dfx emulation (i.e. 3d games from late 90s/early 2000s)?
Is there any way how common bread eaters like me could help to improve the situation anyhow?
Reply 1 of 14, by cyclone3d
There are good 3dfx wrappers for Windows games.
I don't know if any of them are open sourced though.
It really would be best to have hardware passthrough to d3d for stuff like DosBox instead of complete
software emulation for 3d acceleration.
Complete software emulation would absolutely tank performance.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 14, by cyclone3d
After thinking about this more, it would probably be easiest to:
1.Have DosBox pass the calls to a Glide wrapper. No need to re-invent the wheel.
2. Add some multithreading capability to DosBox. Why have everything be on only a single thread?
Why not split the load between different threads? Sure some things must be run serially, but
it would not hurt to break different tasks into separate threads.
3. Give a configuration option to enable/disable multithreading.
YMF7x4 Guide
Reply 3 of 14, by leileilol
Perotin wrote on 2023-06-13, 15:02:
3dfx cards weren't the fastest nor the cleanest. Multithreaded 3dfx emulation's been a thing for years and so are the CPUs that can do it. There's just a couple things left out mutually between the software emulation of them and they're not features anyone talks about.
Also no one's emulated a Voodoo4/Voodoo5 because there really isn't much legally clear and publicly released (NOT LEAKED) tech documentation on that.
Reply 4 of 14, by sofakng
I thought 3dfx (glide) emulation was already in Dosbox and worked fairly good?
Reply 5 of 14, by cyclone3d
sofakng wrote on 2023-06-14, 00:57:
Looks like DosBox-pure and DosBox ECE support 3dfx emulation.
Haven't really looked into that as I haven't really played with any of the forks.
I also see mention of an alpha build of regular DosBox from 2017 with 3dfx support on the DosBox site.
YMF7x4 Guide
Reply 6 of 14, by konc
I believe that a prerequisite for serious discussion about 3dfx in dosbox is official/stable support for win9x, otherwise it's limiting to dos games and therefore not a complete solution. Then again I'm not even sure it makes sense since it's, well, DOSbox. An integration of some software capable of running windows games (PCEm? 86Box? VM?) and an established glide wrapper like nGlide seems more suitable to me.
Reply 7 of 14, by jmarsh
There are problems with both 3dfx and win9x emulation in DOSBox that both boil down to how floating point is handled, the only way it would ever be properly portable would be if someone wrote full x87 emulation code and I don't think that's ever been done for any project.
Reply 8 of 14, by cyclone3d
A question I've had many times is why does the CPU and GPU have to be emulated at all? It isn't like those functions have been dropped on modern processors.
The only problem I see with directly using the hardware would be that you would have to change the way the speed is regulated for speed sensitive software.
YMF7x4 Guide
Reply 9 of 14, by jmarsh
You can't exactly run a CPU in real mode (with full access to segment registers, page tables etc.) from within a program. Not to mention on systems that aren't x86...
Reply 10 of 14, by cyclone3d
Right, so what about using a type of hal instead of full-on software emulation?
If the system it is being run on is x86, then not everything should need to be emulated.
If it is non-x86, then it would be compiled as such anyway and the full software emulation would need to be there.
YMF7x4 Guide
Reply 11 of 14, by thp
cyclone3d wrote on 2023-06-14, 14:00:
This is what the "dynamic" core (dynamic recompilation) does in DOSBox-X, although it seems to be limited to 32-bit x86. The "modern" system you're running on most likely is x86_64 (aka amd64), which isn't the same as x86. Add to that real mode and stuff and things get tricky really fast (there's no Virtual 8086 Mode in Long Mode anymore).
There are also other approaches, like hooking on the library level (e.g. Box86) which can help performance, if you combine that with Wine, you get x86 Win32 apps running on ARM Wine using native OpenGL drivers, for example. Of course, if the app uses software rendering, the library-level hooking doesn't help much.
CPU code can be compiled "ahead of time" or "just in time" to other CPU architectures; non-x86 doesn't mean it can't be translated. This is what e.g. Apple's Rosetta2 (x86_64 binaries on arm64) or Microsoft's x86 (+ x86_64) emulation on Windows 11-on-ARM64 do. It's also what back in the day (Rosetta 1) Apple did (running PPC binaries on x86).
It always depends how "native" you want the environment to look and how accepting the content you want to run is of such a not-fully-native environment.
As an example, with Linux, Wine and nGlide, you can have quite good 3Dfx game support on modern x86_64 machines, with all code running "natively", without emulation (just wrapping) - IF the game itself runs under Wine and is happy with nGlide's implementation of the Glide API. Add Box86 into the mix, and you could probably run 3Dfx x86 games on a Raspberry Pi.
Reply 12 of 14, by leileilol
dosemu's right there. Wonder why it never gained relevance in the 2000s 🤔
Reply 13 of 14, by mothergoose729
Where are the gaps in emulation? What still doesn't work?
nglide is high level emulation that translates API calls AFAIK. There are forks of dosbox, at least, that have a dependency on nglide to support glide games and use it for rendering. I played a few glide DOS using all the features that nglide provides (high resolution, extra filtering, ect).
nglide and dgvoodoo2 are also largely compatible with windows based glide games.
PCem supports voodoo emulation and I am pretty sure it is entirely emulated on the CPU.
Maybe I haven't explored it deeply enough, but I have yet to find an instance where glide emulation was much of a problem.
Reply 14 of 14, by jmarsh
One does not simply "use a HAL." Especially if they want code to be portable.
The problem is you can't selectively emulate some parts and not others.
DOS software expects to have complete control over the entire machine - all the protected CPU registers, ports, memory mappings, PIC...
Modern windows still doesn't even allow mapping memory with native 4KB granularity because some ancient CPU way back when win32 was born had 64KB granularity instead.
And then we end up with an even worse case of the current FPU problem, which is that non-x86 builds only get 64-bit floating point accuracy while x86 builds use the built-in x87 (80-bit accuracy) and forums get filled with arguments between people saying a game/demo works/doesn't work because they don't realize different hardware = completely different performance.
