Install Shield hanging
First post, by filipetolhuizen
On Windows 7 64 bits, every Install Shield app or game that I'm attempting to install just hangs at 99% using their original 16 bits installer under winevdm or won't appear at all using the 32 bits installer replacements. I tried using isfixload.exe for otvdm but it didn't help either. Anything else I could try?
Reply 1 of 3, by BEEN_Nath_58
I usually had a Wait Chain associated with a IS setup that I had to close from Task manager
Reply 2 of 3, by dr_st
It's usually some other process that causes it. In my case it was CoreFTP server which I had running for some obsolete legacy reason.
You can terminate non-MS processes one by one until the InstallShield is 'released'.
https://www.pcgamingwiki.com/wiki/Half-Life#I … tail_version.29
Reply 3 of 3, by filipetolhuizen
Turns out it was iusb3mon.exe. After closing it, both 16 and 32 bits installers started working again. That's really odd, because I had it for ages (since 2017) and it had never caused issues with InstallShield before.
