First post, by philthethrill
I ordered Madeline’s Thinking Games from eBay. When I start the game, it says “Video not available, cannot find ‘vids:arbc’ decompressor.” Any suggestions?
philthethrill wrote on 2024-03-19, 00:53:I ordered Madeline’s Thinking Games from eBay. When I start the game, it says “Video not available, cannot find ‘vids:arbc’ decompressor.” Any suggestions?
Where are you trying to run the game? And which OS did you install it in?
I don't if you were using winevdm to run it but when I tried it I found the same problem. I've implemented support for loading win16 codecs here, https://github.com/otya128/winevdm/pull/1388, which makes this work.
crazyc wrote on 2024-03-21, 01:06:I don't if you were using winevdm to run it but when I tried it I found the same problem. I've implemented support for loading win16 codecs here, https://github.com/otya128/winevdm/pull/1388, which makes this work.
how do I download it from appveyor? Also the deluxe edition of the game doesn't see the OS as supported
BEEN_Nath_58 wrote on 2024-03-21, 05:37:how do I download it from appveyor? Also the deluxe edition of the game doesn't see the OS as supported
https://ci.appveyor.com/project/otya128/winev … 71et7/artifacts
One that I tested didn't have any problem installing.
crazyc wrote on 2024-03-21, 13:55:BEEN_Nath_58 wrote on 2024-03-21, 05:37:how do I download it from appveyor? Also the deluxe edition of the game doesn't see the OS as supported
The game works now. One problem is the game stops sending any messages if I don't Windows-key out of the game
