ddhack
Reply 20 of 33, by aqrit
ddhack doesn't appear to work with any of the ddraw sdk samples
Has any1 given any thought on how to add support for games that load ddraw via CoCreateInstance() ?
Reply 21 of 33, by DosFreak
3D Ultra RC Racers - Fixes color corruption. Max res limited to 800x600 with ddhack
Abuse (Windows) - doesn't work. Game will not execute.
Diablo - Doesn't work. ddraw error.
Dink Smallwood - White screen on main menu. Unable to see anything.
Worms Armageddon Demo - Black screen on execution.
Uprising 2 Demo - Black screen on execution
101 The 101st Airborne in Normandy - Main Menu screen actually pops up but graphics are corrupted.
Neverhood demo - Solid block of color fills the screen
Savage for Windows 95 - Black screen in a window. (Without ddhack you get corrupted graphics in fullscreen)
Make your games work offline
Reply 23 of 33, by Sol_HSA
Great minds think alike, I see =)
http://iki.fi/sol - my schtuphh
Reply 24 of 33, by ghotik2002
Savage for windows 95? what sort of game is it? (and, most important, how to get a copy?)
I'd like to make some attempts to support it with DxWnd ....
Reply 25 of 33, by Stiletto
Pretty savage necropost, but we''ll let it slide since it's the DxWnd author 😀
do the Fandango!" - Queen
Stiletto
Reply 26 of 33, by Azarien
By the way, I noticed that on Windows 10 Anniversary the main problem with 8-bit palette (broken colors) seems to be fixed, at least on the games I tried.
The main reason for DirectDraw wrappers is gone 😀
And contrary to popular belief, it was not a problem with DirectDraw per se - which works fine - but with 8-bit color modes regardless of ddraw.
Reply 27 of 33, by Scali
Yes, and as I understood it, it is 'by design'. That is, in a system where you REALLY use an 8-bit mode, the system might have to 'steal' some palette colours from time to time, to show GUI elements. There are WM_PALETTEISCHANGING and WM_PALETTECHANGED messages for that:
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
But no application ever bothers to handle those of course 😀
I believe one of the "compatibility" options that you can set in the registry can actually block these messages, so the problem is fixed: https://www.sevenforums.com/gaming/100379-how … indows-7-a.html
Reply 28 of 33, by Azarien
Except that on Vista/7/8 they don't work properly. Once in a while you got colors stolen by explorer.exe without any notification.
On the other hand, if you use DirectDraw with 32-bit color - no problem with that.
Reply 29 of 33, by Jorpho
Wasn't the 8-bit palette problem already fixed in Windows 8?
Reply 30 of 33, by Azarien
I don't know. When I tried to run my 8-bit mode demo program on Windows 8 (or 8.1) it didn't work at all.
What I know is that Vista and 7 are heavily affected, and 10 is not.
On XP the color bug can also appear albeit very rarely.
I have made a custom build of Quake 1 that fakes the 8-bit mode in software, using 32-bit color mode at the cost of about 10% fps.
Reply 31 of 33, by DosFreak
It's the demo for Savage The Big Hunt.
https://drive.google.com/open?id=0BwC_OlSsxC1 … Z3J4VE04NFplYXc
Reply 32 of 33, by UCyborg
I think the rainbow palette problem was gone in Windows 8, but something else was broken related to 8-bit palettes. Some games that use 8-bit palette apparently fail to initialize on Windows 8+ while they work on Windows 7. Soulbringer quits with an error message if you select software 8-bit mode.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 33 of 33, by ghotik2002
Uhm, it seems I saw the reply to my question a bit late, but anyway thank you: I got the demo and found it running in DxWnd with very little tuning. Probably some more work should be done to handle the mouse and keyboard (they seem trapped in the game). Here are some screenshots from Win10.
