First post, by neilcoal
i'm trying to make a machine to play old games under win9x & directx6/7,
but i'm having some troubles
1. do you know if it's OK to use a power source of 400W for a computer which previously had a 350W power source (cannot find a 350W power source anymore)
(AMD 1Ghz thunderbird, geforce fx 5500, 512 MB RAM DDR333 (166 Mhz) / or 1GB DDR400, 2 HDD IDE FAT32;
ocasionally, for some games, i'm adding to this a 3dfxv2 card)
sometimes that PC freezes for a couple of seconds
(could that be the reason?)
also the keyboard seems to have problems
(won't take several presses of the same key)
1b. many times (in-games and in-windows) the mouse would freeze that computer (requiring cold restart);
i'm switching the mice, but they are all PS2
is there a tip or a custom driver to fix this in win95?
1c. also, would it be OK to use a 350W power source for a computer which previously had a 300 W one?
2. also, on the same machine i have a dual boot win95 & winXP;
would the settings from 'config.sys' & 'autoexec.bat'
(which i use for DOS games)
affect in any way the winXP installation,
or winXP doesn't read 'config.sys' & 'autoexec.bat' at all
(won't be slowed down by the settings in those files)?
3. audigy 1 has DOS drivers on installation CD
- well, i couldn't find them;
if they are there, would you tell me where?
also, would they work with an audigy 2 card?
does that mean soundblaster compatibility in DOS?
4. how to capture win95 ddraw games?
(full screen & sound)
(preferably freeware tools)
4b. would your recommended capturing tools also work with DOS games running in win95?
especially interested in capturing ef2000 graphics plus (3dfx)
please don't reply unless you know what you're saying
many thanks
