CyberGladiators Xp
First post, by Gamecollector
Game info.
In WinXp Sp3 - the game installing and starting perfectly. Then, in the main menu|demo mode - it working with way too fast FPS. The two warriors for the demo are choosed - three seconds w/o demo or with 1 frame - another two are choosed. Plus the music/sound is also too fast.
"Vertical sync always on" in the driver settings - no reaction.
Tested with P4 3.0E/ 2 Gb RAM/ X850 PE Agp/ Catalyst 10.2/ WinXp Sp3.
P.S. In the WinME - the game is working with desired FPS.
Can someone tell me the way to properly run this game with WinXp?
Tnx.
Reply 1 of 8, by DosFreak
The demo worked fine for me with 2000/XP32bit/200332bit.
For 2003 64bit to 2008R2 64bit I could only run it using Vmware 6 workstation with Windows 98SE as a guest OS.
Strangely on 7 64bit it worked fine with an XPS M1330 and on a desktop with an ATI 5870 video card. On other computers with 7 64bit I had to use Vmware.
It's probable some DirectX\Video driver issue.
Try reducing ddraw\d3d hardware acceleration and\or different driver versions and settings.
Make your games work offline
Reply 2 of 8, by leileilol
Uses a software renderer IIRC. I remember "It's the 3d fighting game with MMX colored lighting!" hype in the day. Man did that not last long.
Reply 3 of 8, by Gamecollector
leileilol wrote:
Uses a software renderer.
Software mode used. The game is glide/software, I don't have voodoo, so...
Reply 4 of 8, by Aideka
Glide wrapper might help, I don´t know if forcing vsync helps when playing software mode games.
Reply 5 of 8, by Gamecollector
Tested with nGlide 0.98. Still the same behavior - too fast.
P.S. I reinstalled Xp and videodrivers. Now the game is working in software mode. But - there is no reaction to keyboard. Just main menu. Still the speed is normal, so - iit is the progress...
With the nGlide the game is still too fast.
Reply 6 of 8, by aqrit
you actually want to increase the ddraw\d3d hardware acceleration slider
cause vysnc fails/ignored if ddraw is in hardware emulation mode
it doesn't seems to be a just a vsync problem because I faked ddraw vsync at 100ms
and the game still runs too fast in parts
the demo seems to be using QueryPerformanceCounter wrong
( not checking QueryPerformanceFrequency )
so the more counts per second your processor has the faster the game runs
unfortunately the EmulateSlowCpu Shim doesn't seem to work here
but if one just hex edits in a longer wait then fights run at a playable speed...
thats how things looks to me
feel free to prove me wrong
Reply 7 of 8, by aqrit
( as per Re: Getting Gunmetal to run properly under win32. )
The game has a sub-function that calls QueryPerformanceCounter and returns milliseconds since game start.
That sub-function incorrectly converts the returned 'cycles' to milliseconds ( shr cycles,0xA )
The easiest fix is to just call GetTickCount instead
GetTickCount returns milliseconds since Windows was started.
A distinction between "game start" and "Windows start" is not needed on the demo.
The demo exe and the full exe seem almost identical.
( note: GetTickCount rolls over after 48 days of uptime... but it doesn't seem worth the extra effort to handle that )
// cyber v1.0
at file offset 00003116 write 0E 30 04 00
at file offset 00003125 write FF 2F 04 00
// cg_demo v1.0B ( http://www.sierrahelp.com/Misc/Demos.html )
at file offset 0000305F write 69 30 04 00
at file offset 0000306E write 5A 30 04 00
Reply 8 of 8, by Gamecollector
Tnx. Have tested the full game.
1) The game is playable now in Xp.
2) The gameplay is 20% slower. And it looks like smooth/normal/turbo option isn't working.
3) Patched version don't needs the EmulateSlowCPU ACT fix. It looks like EmulateSlowCPU isn't fixing QueryPerformanceCounter completely...
And again - big tnx.
