First post, by stefos
Hi everyone,
O.K. here's my situation:
I have 1942 Pacific Air War gold edition but the CD version not the floppy version.
The retail box I have says Windows 3.1 but this was supposed to have been able to install under Windows 95...........My PC has Windows 8.1
I copied the disc contents to my C:\ drive to make installation easy.
When I opened dosbox to run the executable a "this must be run in windows" message appeared in the dosbox command line.
What do I do next?
Any help would be appreciated......I really want to run this game.
Thanks,
Stefos
Update
Would Ubuntu work for this game using Virtual Box?
Reply 1 of 4, by filipetolhuizen
If it's for Windows, it'll not run under DOS Box, unless you have Windows installed inside it.
Reply 2 of 4, by stefos
Would installing Ubuntu work if mounted that?
Also, Where could I buy a copy of Windows 95 from legally?
Stefos
UPDATE:
Ubuntu will NOT run on Windows 8.1
Reply 3 of 4, by filipetolhuizen
It'll work under Ubuntu if running inside WINE.
