Reply 20 of 66, by mirh
VirtuaIceMan wrote:
Right, my final take on this: 1. Needs ALchemy applied to the game folder to even start the game. 2. Audio will smisbehave and/o […]
2. Audio will smisbehave and/or crash if DS3D is selected.
3. Audio will crash if EAX is selected.
4. Audio will not play at all if Dolby is selected.
5. If sound is not set to Low then it'll stop playing after a few seconds and hitting escape will lock the game up.
6. Enhanced channels is possible with any setting without affecting what that setting does (i.e. can use Low and Enhanced and it'll work).
6. However, HOWEVER... selecting A3D 2.0 allows CD quality and Enhanced, and *seems* to work fine!
I hope you know that without any driver at all... A3D is just nothing. If you are lucky though, the game will have built-in dll and it will fallback to DS3D (or to IA3d5 interface if you are lucky and under x86 windows)
Anyway, did you try to adjust ALchemy settings in the .ini file?
pcgamingwiki.com
Reply 21 of 66, by VirtuaIceMan
I did not. And A3D 2.0 sounds better than Low quality audio with nothing chosen.
Incidentally during my "journey" I spoke to one of the programmers of the game, who said: "Ah, something to do with the sound then ? We wrote all our games in assembler code, not C++ and I remember we used to still use the sound interrupts, or something crazy like that. Or maybe I’m getting confused with some of our older games."
My PC spec: Win10 64bit, i7-4970K (not overclocked), KFA2 GeForce RTX 2070 SUPER, Creative Soundblaster ZXr, 16GB RAM, Asus Z97-A motherboard, NZXT 410 case, ROG Swift GSYNC monitor
Reply 23 of 66, by VirtuaIceMan
I don't know about his issue; he's using a Radeon. I also note that the error messages are in Polish, so he might be running a slightly different build of the game.
Reply 24 of 66, by Mud
I have Nvidia 540M with great visuals.
https://youtu.be/PXgq8JC2Avc
Haved similar problem on my old pc with Geforce and there downgrade drivers solved problem, but no on this notebook.
Any ideas how to fix that?
Edit.
SOLVED!
I downloaded old graphic drivers from Notebook producent page dedicated for my model and work great 😊
Unfortunately nvidia have in ass support old games, latest drivers are completely incompatible with RC.
I didn't noticed that problem with Radeon, this card is more prefered to run older productions.
@tgomola
dgVoodoo nie działa u mnie,masz szczęście że ci chwyciło. Testowałem na czterech sprzętach i uruchomił mi się tylko na jednym
Reply 25 of 66, by tgomola
Use dgVoodoo. I have exactly the same version of the game (KS Gry 😉 ) and GeForce GT755M. Works like a charm.
Reply 26 of 66, by filipetolhuizen
How come? This game relies on Direct3D only and does not use Glide2x.dll at all...
Reply 27 of 66, by mirh
Mud wrote:
I have Nvidia 540M with great visuals. https://youtu.be/PXgq8JC2Avc Haved similar problem on my old pc with Geforce and there do […]
Edit.
SOLVED!
@tgomola
Many times it's just a dll that needs to be replaced. Couldn't you find it?
I mean.. you install current drivers and tries to place older one in game folder.
pcgamingwiki.com
Reply 28 of 66, by Mud
Edit.
SOLVED!
@tgomola
I dont hear.
Is topic about that? write something more about that
Reply 29 of 66, by tgomola
dgVoodoo 2.xx emulates DirectX 1-7 as well.
PS. My GPU driver is always up to date, I have never been forced to install older one. Usually dgVoodoo, nGlide or DXGL fix the problems with old games, sometimes MS Application Compatibility Toolkit is needed, and that's all. I've got a lot of older games installed and working flawlessly on Windows 8.1 64 bit 😀
Reply 30 of 66, by Mud
Dgvoodoo is incompatibilie with Intel graphic (dev have problem with Intel messy drivers)
...better story; have notebook with integrated Intel plus dedicated nvidia gt540 and there i can't too use dgvoodoo because it work with optimus system (automatic switching card). GF work only when i play, on the desktop switching back for Intel HD graphic and i can't configure in dgvoodoo my nvidia graphic card because is deactivated 😵
Reply 31 of 66, by mirh
Edit.
SOLVED!
@tgomola
I dont hear.
When you install graphics drivers there are some .sys file (which are kernel mode drivers) and .dll which are user mode libraries (I hope I'm not saying BS)
Anyway, you can often swap the dll of one version with the drivers of another one (I never hear somebody doing the same with .sys, but you never know). As demonstrated with pandora tomorrow problems, this may be of help
pcgamingwiki.com
Reply 32 of 66, by filipetolhuizen
Really? Now that's some very interesting news. Now I can play Rally2K without garbled menus and MDK D3D without the texture glitches. It might fix Falcon 4.0 garbled arming screen as well...
Reply 33 of 66, by tgomola
This shouldn't be a problem, I also have a laptop with two GPUs, Intel and GF, and I have absolutely no issues with dgVoodoo. Are you sure you're running RC2000 with GF?
Reply 34 of 66, by Mud
Ok, now is work. Needed back for latest drivers 🤣
Reply 35 of 66, by Mud
So that's it, A3D 2.0 and ALchemy applied to the game folder = works!
I have disabled A3D 2.0 option on all my computers 🤣
how fix it?
Reply 36 of 66, by filipetolhuizen
I think ALchemy will let you choose it. But for me, the game always crashes when alchemy is in the game's folder. Rally2k tend to hate sound wrappers.
Reply 37 of 66, by Mud
ALchemy unlocked only EAX, A3D 2.0 was still locked 😵
It's crashing me too. Sound work 30 sec, then i loose them and when i push ESC game getting stuck and crashing 😢
Reply 38 of 66, by filipetolhuizen
I get Guru Meditation upon starting a race.
Reply 39 of 66, by Mud
doVoodoo definitely solved my problems with guru mediations.
desynchronization is less frequent if you have during game stable fps and no over 60fps to dont make crash.(frame-limiters make desync.sound)
On the stronger computers best way is play on one core with dgvoodoo, then you have solved all problems and you can play normal without errors and desync.sound.
Weaker computers have problem because playing on one core make drastic drop in fps, dgvoodoo like too eat some fps and we have problem with liquidity
