Patch Name: Sin 1.03 update - "Update from 1.01"
Instructions:
This patch updates your previously patched version of Sin from 1. […]
Instructions:
This patch updates your previously patched version of Sin from 1.01 to 1.03. You must have at least version 1.01 before running this patch. If you have not previously patched your Sin game, download "Sin Update 1.01" and run that first.
There is one inclusive file named sinupdate103.exe, it's a 2 meg download taking 10 minutes from a 28.8 kbs.
Setup:
Sin 103 update rewrites your autoexec.cfg and your default.cfg. If you have changed these in any way, you may want to back them up in a different location as they will be updated to the 1.03 version.
Double click the file and the installation will begin.
Three dialog boxes will appear. Read each box carefully and then proceed.
A. You must have previously updated you Sin version to at lease 1.01.
B. Original Sin players are not supported to play on Wages of Sin servers. You must have Wages of Sin to play on Wages of Sin servers.
C. Sin will be updated to version 1.03. Previous save games may not work.
Sin Update 1.03 will continue and conclude.
