XWA - finicky on some systems?
Getting old Windows games working.
Postby buckeye » 2017-1-11 @ 19:40
Don't know if this needs to be in "Marvin" so will try here. Having trouble getting this game to run smoothly on my Win98 system -see sig for specs. A lot of it is probably due to a crappy CD/DVD drive but also for when I run the game's hardware test it's trying to say my DirectX version is 4 when actually it is version 9.0c.
So in a nutshell, can anyone recommend any system specs. that might run this game better and what directX version might be a little less "twitchy"?
Intel SE440BX P3 450 384mb 40GB Hercules 3D Prophet II Ultra 64MB SB Live! 5.1 350W
Foxconn Q45M E8400 Core2 Duo 2GB DDR2 800 160GB BFG Geforce 7950GT 512MB 500W
User avatar
buckeye
Re: XWA - finicky on some systems?
Postby gerwin » 2017-1-11 @ 19:44
X-Wing Alliance? I run it on an 3,3 GHz Ivy Bridge system with Windows XP SP3 ;).... Used the XWA hacker fixedclear patch though for the radeon videocard specific glitches. On intel HD graphics it runs fine without any modifications.
There was this issue though: If you use the latest v2.02 patch, it may want to use A3D audio when it finds (leftover) A3D related dll files in your system.
User avatar
gerwin
Postby Jorpho » 2017-1-11 @ 20:50
buckeye wrote:when I run the game's hardware test it's trying to say my DirectX version is 4 when actually it is version 9.0c.
If it's reporting the version of your DirectX DLLs, then it will always start with 4. The DLLs for DirectX 9 would be 4.09.xx.
User avatar
Jorpho
Postby buckeye » 2017-1-11 @ 22:06
Thanks Jorpho for responding. Ok that makes sense about the DLLs, but forgot to mention that it lists some that are missing. Is this because it's looking for older version DLLs? My other games run fine no problem.
User avatar
buckeye
Postby Jorpho » 2017-1-11 @ 22:35
buckeye wrote:it lists some that are missing.
It's a bit pointless to speculate without knowing which ones.
You mentioned in your other thread that you have Daemon Tools. For testing purposes, why not just take your optical drive out of the equation, and see if it works with a BIN/CUE image?
User avatar
Jorpho
Return to Windows
Who is online
Users browsing this forum: No registered users and 3 guests
