UT99 Galaxy Audio Driver Crash Win10
Getting old Windows games working.
Postby NightSprinter » 2017-7-13 @ 16:13
Curious, has anyone had UT99 just outright crash on Windows 10 with the Galaxy Audio Driver selected? I mean, the game works just fine on the Win98 box, and on this if I have a different driver selected. Just curious as to why Galaxy crashes.
NightSprinter
Re: UT99 Galaxy Audio Driver Crash Win10
Postby DracoNihil » 2017-7-17 @ 11:48
Could you post the crash? I've had Galaxy crash sometimes in weird situations before, no matter the OS. But I haven't had Galaxy crash in Windows 10 on any Unreal Engine 1 game. (Unreal, UT99 and Deus Ex were tested)
User avatar
DracoNihil
Postby NightSprinter » 2017-7-17 @ 18:03
Thing is, I can't generate a report. The window just freezes as the game opens up. I switch over to the new OpenAL renderer, and the game runs as intended.
NightSprinter
Postby DracoNihil » 2017-7-17 @ 22:07
Try setting Latency to 80 in the UnrealTournament.ini under [Galaxy.GalaxyAudioSubsystem]
If that doesn't work then could you tell me what audio device you're trying to use?
User avatar
DracoNihil
Postby NightSprinter » 2017-7-17 @ 22:56
Nope, still doesn't work. Here is what happens
NightSprinter
Postby DracoNihil » 2017-7-18 @ 14:43
This is going to sound dumb but can you forcefully disable Data Execution Prevention (DEP aka NX Bit) on your system and run Unreal as Administrator?
User avatar
DracoNihil
Postby NightSprinter » 2017-7-22 @ 02:04
Yeah, gave it a shot with NX Bit disabled. Wound up the exact same result. I'm wondering if there's something with Windows 10 (as well as versions going back to 7) that breaks compatibility with the Galaxy audio driver for the game?
NightSprinter
Postby NightSprinter » 2017-7-22 @ 12:46
Yeah, that is basically the only way for me to play it. Was just wondering, since I read inconsistent things on other sites that people supposedly got the original audio driver working in newer versions of Windows.
NightSprinter
Postby DracoNihil » 2017-7-24 @ 12:55
The FMOD and OpenAL audio devices for UT99 have really lame music playback compared to Galaxy and aren't even properly compatible with the Reverb settings in ZoneInfo actor properties. So I never really recommend those... I really don't know what's going on at your end because Galaxy works just fine for me, and this is on Creators Update apparently...
User avatar
DracoNihil
Postby NightSprinter » 2017-7-24 @ 17:08
Yeah, and this was from a fresh install and update. I will see if copying the Galaxy driver from my Unreal Gold install will do anything. Also will see how it works with A3D-Live installed.
NightSprinter
Postby DracoNihil » 2017-7-24 @ 19:40
Don't try to copy Galaxy.dll from other Unreal engines to UT99, they're not guaranteed to be compatible let alone properly linkable...
User avatar
DracoNihil
Return to Windows
Who is online
