Doesn't work. Literally. As in, I can install it, but it gamma and brightness don't change no matter how much I screw around with the sliders.
ARGH!
All I want to do is play TIE Fighter! Is that so much to ask?! First my pilot keeps disappearing, then the graphics don't function... I solve the graphics problem by installing it on a true, hardware DOS box. I learn that the reason the graphics were so screwed up in Windows XP (my normal machine) because the sound and graphics never decompressed correctly in WinXP, 'cause Microsoft's a bunch of bastards who hate DOS.
I try to get a joystick working on the DOS box. No luck. Win98SE rejects every joystick I throw at it, saying I have my maximum even though there are none installed!
I try to install TIE Fighter in DOSBox, it won't accept floppy disk 2 -- it keeps telling me to insert floppy disk 2 when floppy disk 2 is indeed inserted, and I know it works because I installed it on the Win98SE DOS box machine.
Thanks,
Robert Aronson (Shoal)
