How to Run Anachronox on XP
Getting old Windows games working.
Re: How to Run Anachronox on XP
Postby Davros » 2013-9-06 @ 20:07
just wondered what would happen if you try and leave the starting map without buying a battery for pal ?
User avatar
Davros
Postby Gamecollector » 2013-9-06 @ 21:00
Davros wrote:Is this the same location as your first screenshot ?
Almost. Wrong blending is in the lift only. Lift glass must be fully transparent.
I have attached the fraps movie to show the effect exactly. http://www.4shared.com/video/9fh9A_78/Anox.html
IIRC you can't enter the bus to the Spaceport, Boots will say something about "I need my old friend".
User avatar
Gamecollector
Postby CrisGer » 2013-9-07 @ 00:23
thanks for the Doorlord fix, . Even after the amazing work done by Chinaman during his long solo effort that added so much to this wonderful game we still have a few spots that take work to get thru. I am replaying to see the side quest that you get when you choose the bot as a party member...the other side quest was wonderful and loved what you got to see. A truly remarkable job and Tom Hall has so much more to do and it is all planned out and scripted..just looking for a backer and publisher, and working with Square Enix to get them to particpate. One step at a time but at least we sill have Tom, even tho he had a stroke not too long ago ... so there is hope to see the story finish.
and i will try to conform where to find the tooth for you sorry to have not helped with that yet... too much going on .
Admin
3D Worlds and Game Developers Group Linkedin
http://3dworldandgamedevelopers.blogspot.com/
User avatar
CrisGer
Postby Davros » 2013-9-07 @ 17:22
ps: there is a bug on a quest early on you need to follow a guy to find eddie
you lose the quest on level transitions so you need to use a slowdown utility during that task
User avatar
Davros
Postby Davros » 2013-9-07 @ 22:01
re the orange light in sendormitory
gog version is supposed to be fixed
also read you can run it with nglide and its fixed I tried this but didnt seem to work maybe I didnt do it right and nglide wasnt being used
User avatar
Davros
Postby Gamecollector » 2013-9-07 @ 22:56
NGlide run Anachronox through the MetaGL. Install nGlide, run the file anox_v2v3.bat in the gamedir.
Metagl (trial version) is included with 1.02 build 44 patch. And with the GOG version, by the way.
The trouble is - no hi-res mode, because glide isn't supporting 1280x960 mode (gl_mode 8 ), only 1280x1024.
I will test the GOG version and will tell results.
*Censored*, my Anox saves are dead... :(
User avatar
Gamecollector
Postby Davros » 2013-9-08 @ 09:12
you can have my saves but im not far into it
ps: cant use metagl + nglide menu's all messed up
edit: use opengl type gl_fog 0 in the console
User avatar
Davros
Postby Gamecollector » 2013-9-08 @ 21:24
No, GOG version have the transparency glitch.
More places to see this: Mystech Museum (demonstration cases), bookstore in Tenements (front glass)
Plus it looks like there is no fog in museum with Radeon HD2600.
User avatar
Gamecollector
Postby [Zeus] » 2013-9-26 @ 19:04
Davros wrote:ps: cant use metagl + nglide menu's all messed up
Which nGlide version did you use, Davros? IIRC this bug was fixed in 1.00.
User avatar
[Zeus]
Postby Davros » 2013-10-01 @ 14:06
0.95
Thanks for that will upgrade
User avatar
Davros
Postby CrisGer » 2019-6-12 @ 13:10
OK years later i am trying to replay Anachronox and found that the GOG version is NOT fully patched and is missing stuff.
i hope to get it going once i find my own original disk.... but i see from old posts i will need to turn on extension limit...one way is to edit the dll but can anyone tell me what program to use to open it up to edit it?
here is the post about this from some years ago..wow how time flies..
Postby Gamecollector » 2013-9-04 @ 14:20
Another method is - edit ref_gl.dll, find strings "GL_EXTENSIONS: %s" and replace "%s" to "%p". This is working for all Q1 and Q2 engine games, by the way.
Admin
User avatar
CrisGer
Postby Gamecollector » 2019-6-21 @ 00:45
Far Manager.
User avatar
Gamecollector
Postby hwh » 2019-7-09 @ 03:54
...retail version doesn't have the transparency bug?
hwh
Previous
Return to Windows
Who is online
