Reply 20 of 64, by dud716
- Newbie
Thanks, Nicht. I hope that you had some sleep:)
Now, on to the business at hand....
I don't understand the BOOT.INI info, ....is this used for the trick install, in other words, is this used if I want to install WIN 98-SE after WIN XP?
If so, perhaps, you did not understand my previous post....(or, I didn't understand your previous post. )
Make sure that you have a copy of your BOOT.INI file copied to a floppy (make sure it's not hidden or read-only). Otherwise, you will be crying.......
It's needed if you're going to try installing Windows 9x after XP. after is the key word here.
XP creates this for you during a normal install. If you try the trick-install, you have to manually edit the BOOT.INI file. It's a lot easier if you have your original BOOT.INI file to use as a template....
I DO NOT want to install WIN 98-SE after WIN XP, actually, my intention, ( actually, my hope!), is to COMPLETELY wipe my HD, and then start all over with a clean Hard Drive.
The following are the steps that I will follow...
1.) Wipe HD
2.) Install WIN 98-SE, and associated drivers
3.) Install PARTITION MAGIC 8.0
4.) Create two partitons.......
a.) C:--- partiton for WIN 98-SE
b.) ?:---partiton to be used for WIN XP-HOME
5.) Install WIN XP-HOME, and associated drivers
NOTE: I will follow your suggestion.....
I recommend creating a bunch of tiny little FAT partitions before installing XP. That way XP has high-letter like N: which will help prevent drive-letter-juggling when you add partitions. That way, D:/SIERRA/KQ5 STAYS D:/SIERRA/KQ5 whether I'm in 98 or XP. I delete the tiny partitions after XP has finished installing.
First things first.....
I have to download and burn all of the required drivers for both OS's, and back-up all of my files. (I still have issues here....) After I do this, I should be able to begin the above process. I'm not sure about the IBM HD (60 Gig., see profile). I have to use their (IBM's) Dynamic Disk Overlay, so I'm still looking into things...
I'll let you know what I find in my travels.... for now, Thanks for the info.
P.S. Thanks for the attachment.
P.P.S. What is your opinion about using FAT-32 for both Operating Systems? Wouldn't this allow me to swap files between the two OS's?
Muchos gracias,
dud
...in that quiet earth"
