Reply 20 of 27, by Jorpho
- l33t++
You're definitely going to have to register it within 16 hours, as per the links in the comments and the readme.txt .
As for installing, I think in the specific case of Paragon products offered through GAOTD, running the Setup program for the first time (which requires an Internet connection) will leave the .msi file somewhere where you can run it again whenever you want, without a connection.
