First post, by Twoflower
On Windows XP Pro SP2 (32bit) I have the following problem:
first all 6 discs are copied/installed correctly, but after that, UniSCI.exe starts, but it encounters a problem. (See attachment 'First error')
When I try to run GK2 after that, I get an internal game error. (See attachment 'Second error').
Is there a way to get GK2 working this way? Or should I try it with a virtual pc or maybe even an old pc with Win98 or older?
    21.77 KiB
    Second error
    78.86 KiB
    225 downloads
    First error
Reply 1 of 4, by collector
That just means that the game can't find its resources. check that your RESOURCE.WIN has the right paths.
Reply 4 of 4, by Wintermute
You should have posted only the first error message, because it is very easy to miss - since the picture of the second error is directly shown and the first not.
Furthermore the second error is irrelevant, since it only says, that some files are messed up, which is natural, because your installation crashed because of the UniSCI error.
Relating to your problem: Do you have Administrator rights on your PC?
