FIFA Soccer 96 on Windows Vista
First post, by zelenog
I bought a CD version of FIFA Soccer 96. I have Windows Vista and when I try to install the game, a window pops out and says that "this system doesn't support full screen mode. Plsease close the program."
What do I do? How do I make this game run on my Windows Vista?
Reply 1 of 43, by MiniMax
Rank Moderator
Moderator
You could always try installing DOSBox, then install & run the game from inside DOSBox.
_________________
Reply 2 of 43, by zelenog
Ok. Thank!
Could you provide a link for me to install ALL versions of DOSBox (0.63, 0.65 and 0.70)?
Thank you!
Also, I don't like my new Windows Vista very much. Can I downgrade my PC to windows XP or Windows 98 or Windows 95.
I have all the CD at home to install these OSs.
Plz respond 😀
Reply 3 of 43, by abyss
Well if the computer has 1 ghz or more then don't even bother trying to run windows 95 as it won't work and if the computer has over 512 megs of ram then don't don't bother trying to install windows 98 or windows 95 as it just won't work. I have heard of windows 98 running on 2.4 ghz computers quite well so i don't know the max speed windows 98 can handle but i am not sure on windows me. Windows me and windows 98 are the most likely to work though.
Reply 4 of 43, by dvwjr
abyss wrote:
"Well if the computer has 1 ghz or more then don't even bother trying to run windows 95 as it won't work and if the computer has over 512 megs of ram then don't don't bother trying to install windows 98 or windows 95 as it just won't work."
Now one of my test PC workstations contains an Intel Tualatin 1.4GHz on an Intel 440BX based motherboard with 768MB of 133MHz SDRAM. The multi-boot menu allows testing with many operating systems, among them are Win95 OSR2.1 (Dell), Win98 and Win98SE.
They all work fine. 😕
Then again, it might just be me...
dvwjr
Reply 5 of 43, by MiniMax
Rank Moderator
Moderator
Not just you. I can tripple-boot into Win95, Win98 and XP on my 2 GHz AMD 2600+ with 1 GB RAM just fine.
I guess abyss has a problem distinguishing between "I can't get it to work" and "It won't work" 😀
_________________
Reply 6 of 43, by zelenog
OK guys. You gotta help me. I am trying to create a folder but I can't find that option on Windows Vista that I just bought!
I knew how to do it on XP, but not on Vista. Can you help me? I need to know how to create a folder.
Thanks in advance.
Reply 7 of 43, by zelenog
Really? You mean when I order a customized PC, I can ask them to include all three versions of Windows, and run them just fine?
Reply 8 of 43, by MiniMax
Rank Moderator
Moderator
Ask them can't hurt. But I guess they will also want you to pay them.
_________________
Reply 9 of 43, by zelenog
OK.
I tried to install the game from dosbox and it didn't work. What am I doing wrong.
First of all, I used DosBox version 0.70
My CD is in Drive E
Here's what I did:
1. mount D E:\ -t cdrom –ioctl
2. D:
3. dir.exe
There I found FIFA96 EXE, so I typed FIFA96.EXE and the window displayed this message " FIle Read Error"
I did the same procedure with dos box versions 0.63; 0.65 and 0.71 and they all had this "File Read Error"
How do I install the game and run it? Please guide me through step by step. It's 96 and not that old, so it should run on my pC. I hope 😀
Please reply
Reply 10 of 43, by MiniMax
Rank Moderator
Moderator
Check my signature and the links.
_________________
Reply 11 of 43, by zelenog
I followed that 60 seconds guide guide on how to run games for PC users and. It didn't work.
Again, can you guide me through on how to install that game?
I've read somewhere that the CD version DOES work Perfectly on dosbox 0.70
if it worked for other people, then I must be doing something wrong.
Plz help
Reply 12 of 43, by eL_PuSHeR
What mounting commands did you use?. You should write them down here.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 13 of 43, by zelenog
Well, like I said above, I used the following commands:
"My CD is in Drive E
Here's what I did:
2. D:
3. dir.exe
Reply 14 of 43, by DOS_Boy
Maybe your CD is suffering effects of age...
"But listen to me brother, you just keep on walking, 'cause you and me and sister ain't got nothing to hide..." - Scatman John
Reply 15 of 43, by zelenog
No the CD works. Apparently other people had the same "read error" while running the game on XP.
I am sure that the CD works. I think I am doing something wrong though...
Any suggestions?
Reply 16 of 43, by MiniMax
Rank Moderator
Moderator
zelenog wrote:
Well, like I said above, I used the following commands: […]
Here's what I did:
2. D:
3. dir.exe
Then you didn't follow my 60 seconds guide. Where is the mounting of C ?
_________________
Reply 17 of 43, by zelenog
I created a folder in my C drive called FIFA 96.
But when I tried to mount it, it said that this directory doesn't exist?
Reply 18 of 43, by ADDiCT
I DID that! I created a folder in my C drive called FIFA 96.
Wow! That's an achievement. Time to celebrate!
FIFA 96
FIFA96
Where's the difference between these two?
I don't think anyone will hold your hands here. You could ask your mum, but i doubt she knows how DOSBox works. Read the readme. Read the FAQ's and guides on this forum. And, most impotantly: try to use your brain.
Otherwise I will keep posting questions here forever and I don't have much time these days.
Aha. And we have the time to walk each id... - ehm user through every single game?
Reply 19 of 43, by MiniMax
Rank Moderator
Moderator
Where on the drive did you create it?
And - as ADDiCT said - spaces are important. If you need the spaces enclose the name in spaces:
mount C "C:\FIFA 96"
_________________
