Discworld II
First post, by Franklinsteiner
I followed this guide:
Discworld 2 in XP using DosBox
and this screenshot is what I did:
(Click to get it bigger)
HELP NEEDED:
When I click on the dosbox.exe (I assume it's the program itself right? The brown dosbox icon?) nothing happens! A black screen comes up and just goes away again. Have I copied the files correctly? Or not?
Please help!
If it helps, I have two bin files (Dw1.bin and Dw2.bin) and also two cue files as well. I used ultraISO to rip the Dw2 discs.
Many thanks in advance,
Franklinsteiner
Reply 1 of 8, by MiniMax
Rank Moderator
Moderator
My guess is that DOSBox tries to read the file DOSBox.conf but don't realize that it is a short-cut. And then it simply dies because it gets confused.
_________________
Reply 3 of 8, by MiniMax
Rank Moderator
Moderator
Nope - that is not it. Just tested that.
What do you have in that configuration file?
Have you tried creating a CMD-window and start DOSBox from the prompt? Maybe with the -noconsole option?
_________________
Reply 4 of 8, by MiniMax
Rank Moderator
Moderator
And remove that 'exit' from the autoexec section of DOSBox.conf.
_________________
Reply 6 of 8, by MiniMax
Rank Moderator
Moderator
Franklinsteiner wrote:
What happened here?
I guess you lied.
_________________
Reply 7 of 8, by Franklinsteiner
Well I don't have a dw2.bat exactly. I thought that perhaps dw2.bat who stand for batch so I used my dw2 ms dos batch file instead.
I wasn't lying, just didn't think it was nessacary.
Reply 8 of 8, by Darth Marsden
Are you still having problems with this, or did you sort it out?
Normally I wouldn't bump a week-old topic, but since it's my guide you're following, I'd just like to make sure everyone who uses it gets the game working properly.
EDIT: For anyone curious, he did get it fixed in the end. Huzzah!
