First post, by cailamaia
Let's see. Stuff that might just be useful:
* (can't seem to find the motherboard specs. oops)
* Intel Celeron M 1.50 GHz
* 2 Gb RAM
* Integrated video card (Mobile Intel 915GM/GMS,910GML Express Chipset)
* Integrated sound card (Sigma-Tel Audio)
* Win XP Pro SP2
* Game title: The Lost Mind of Dr. Brain (also known as Dr. Brain 3)
* Description of problem:
The game requires that it be run in 256 color mode, and I have tried setting that in the compatibility wizard, but the colors, when I run the game, are somehow not displayed properly. The characters in the foreground are rendered correctly, but the background seems to be inverted somehow. I tried running it in Win95 compatibility mode, too, and that did not help at all. I'm not sure what else to try.
Now for the recommended list of Helpful Stuff:
* Reproducibility of problem: always, regardless of what settings I use
* Sound mode used: default
* Video mode: 256 colors(required), and the rest default
* Version of emulator: none used
* Steps already attempted to solve the problem: as described above. I've also googled the issue, and got nowhere, though I did find this community. Here's to hoping y'all can help.
Reply 1 of 18, by collector
Compatibility mode may not be working for you. Try setting the color depth to 256 colors manually in the advanced display settings.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 3 of 18, by cailamaia
@collector:
That's a good idea, but I can't seem to find the option to do that. There's a link at the bottom to "Learn more about running programs in 256 color mode", but no option to set it. I've tried the right-click-and-set-it-in-the-properties trick, and that doesn't work either.
@F2bnp:
I've never noticed it offer a DOS install, but I'll look again. That might just work.
Reply 4 of 18, by DosFreak
Try changing your desktop color to 256 colors by right-clicking on the desktop and going to properties.
Make your games work offline
Reply 6 of 18, by wildweasel
I feel a bit of (not exactly) helpful explanation is in order...
Lost Mind was one of Sierra's first Windows-exclusive games. There was no DOS installation on the disc whatsoever. As for why there is no 256-color option, that was inexplicably removed in Windows XP. However, if you have an Nvidia video card, the Nvidia Control Panel included with the drivers will allow you to force an 8-bit color depth, so maybe that will work.
Technically though, it IS possible to run Lost Mind through DOSBox - if you have Windows 3.1 installed in it. I don't even think it requires the Win32 extensions - just run it straight off the disc.
Reply 7 of 18, by DosFreak
You can also go into the Advanced Settings -> Adapter -> List all modes and choose 256 colors in there.
Reply 8 of 18, by cailamaia
@wildweasel:
I don't have a graphics card. Wish I did. Thanks for the explanation about the install and such, though. That actually helped a fair bit.
@DosFreak:
I've managed to set the colors, as you suggested I do. And it worked. But now the colors on my screen are all messed up. Which leads me to believe it's not windows, but the drivers... or some such.
Reply 9 of 18, by DosFreak
Well now that we know that works then you can use this utility:
http://www.softpedia.com/get/Multimedia/Video … ools/QRes.shtml
in a batch file to execute the game and change your color depth for you and then switch it back when you close the game.
Of course the biggest issue there is if you want to do other things while playing the game then you'll have to put up with 256 colors.
So unless someone has hacked\patched the game to fix this issue then your only other option is to run the game in DosBox\Qemu\VirtualBox\Vmware or VPC.
Reply 10 of 18, by DosFreak
This utility can also do the same thing and the developer is still active:
http://alter.org.ua/en/soft/win/vidcontrol/
Reply 11 of 18, by cailamaia
Well, given that the problem isn't the resolution or the lack of ability to set the colors, I think I may be stuck, then. I can change the colors and resolution already without the two utilities you so kindly pointed me towards. The problem is more that the colors don't want to display properly.
I think I'll check on my chipset drivers and, if that doesn't work, maybe give it up. Unless there's something hopelessly obvious that I'm missing.
Reply 12 of 18, by eL_PuSHeR
I am using Windows XP SP2 and I still have the option to "run in 256 color mode" in the compatibility tab.
    6.97 KiB
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 13 of 18, by DosFreak
I thought you said that switching the desktop to 256 colors fixed the game? If so then using the above utility to change the color depth easily would work.
I have the same video chipset in a Dell Latitude D510. I don't have the game but I do have many games from the same company and my "fix" for those kinds of games is to use DosBox/Qemu (or you can use Vmware/VirtualBox/Qemu/VPC). I do this instead of using the utility because I don't like my desktop changing to funky colors and I like to read the web while playing a game.
and I think he stated up above that he already tried the 256 colors in the compatibility tab but it did not work. (He didn't phrase it that well though).
Reply 14 of 18, by cailamaia
Heh. Sorry if I wasn't clear. I made it as clear as I could.
Yes, I have the option. No, it doesn't work properly. I have tried running it in 256 color mode, and what I get is that the characters in the foreground are rendered correctly and the colors of the backgrounds are all funky. I can upload a screencap if it will help clear up my explanation.
Reply 16 of 18, by leileilol
just so you know, I get the same issue with SQV on Win98SE back in '00 with a Geforce2 also in 256-colors, so it's not totally XP related, but more related with non-ISA video card palette access in Sierra's code.
Reply 17 of 18, by cailamaia
It turns out that if I try to run anything else beside the game that requires the use of the graphics card to run, it messes up the colors. I had AllWallpapers running in the background, when I got it to work the first time, and the first cycle of the wallpaper skewed the colors of the game horribly, and once I turned off the other program it worked fine.
Problem solved. Thanks, all.
Reply 18 of 18, by collector
On some systems Compatibility mode doesn't seem to work to automatically change resolution or color depth. Lowering refresh rate sometimes helps. On such systems, the only sure way to change it is to manually set the display settings or to use a utility such as DosFreak posted links to.
