First post, by Necromancist
I recently downloaded Alpha Centauri as an ISO file (i had to, couldn't buy it anywhere). When i tried installing it the setup.exe file wouldn't run, so i was advised to install it through DosBox. Problem is, i have no idea how to do it.
I'm using Windows XP with service pack 2 and the latest version of DosBox. The ISO is mounted in Deamontools with all emulation options on.
Reply 1 of 14, by DosFreak
Alpha Centauri is a Windows game. It works fine in Windows XP if you have an uncorrupted copy which you can get by buying the game.
Make your games work offline
Reply 2 of 14, by Dr. Riptide
Amazon has a number of copies, even of the Linux version, and I'm sure there are plenty lurking on eBay. You can find it if you look.
Intel Q6600 (2.4 GHz) | 4GB RAM | GeForce 8800 GT | Windows 7 64-bit
Reply 4 of 14, by WolverineDK
Sorry to curse at you, but that is complete and utter bullshit. A friend of mine who lives very close. He has both Alpha Centauri and the expansion (original). And before his PC went fucky on him, then windows XP still didn´t want to have anything to with the game. So my answer is , if you have the game, how did you make it run in XP ?
And his windows xp pro is a legal copy I bought him.
So how did you make the game run in XP ? Since when he had Windows 98 SE, there were no problems running that game. But XP refuses on his pc running the game.
Reply 6 of 14, by Dr. Riptide
If you do have a valid copy of the game, there is a patch available to make it run properly on 2000 and XP; The Patches Scrolls has it.
Reply 7 of 14, by WolverineDK
Thanks, I needed that answer. My friend will be happy about that answer , could you by the way give me a link to that patch ? and DosFreak: Sometimes you are cool, other times you are cruel.
Reply 8 of 14, by MiniMax
Rank Moderator
Moderator
The Patches Scrolls
_________________
Reply 9 of 14, by WolverineDK
MiniMax wrote:
Damn it, I was talking about a direct link to the patch. And yes I know how to use google, Not a joke link. And that is it. And I know the patches scroll link.
I don´t need a joke link thrown in my face. And I know when I pushed on the following link I saw the patches scrolls link. And MiniMax I am NOT a stupid Dane !
Anyway I have found the patches, and Dr. Riptide thanks for mentioning about the patch.
Reply 10 of 14, by DosFreak
Can someone explain what the 2000/XP patch does? Is it for an earlier version of the game?
I've installed the Alpha Centauri Demo and Full games on NT4/2000/XP (32 and 64bit)/2003 (32 and 64bit)/Vista (32 and 64bit) and never encountered any issues.....
Reply 12 of 14, by Dr. Riptide
I had forgotten about that .ini file edit; that may be all that is needed to get the game to run even on some XP systems (if that much, I don't know exactly why the game doesn't work most of the time on XP, so I can't say).
I can't find any specific information as to what exactly the 2000/XP patch does (but that doesn't mean there isn't any...). It is dated about two and a half years later than the last "regular" patch for the game (4.0, 2.0 for expansion), so I assume it is intended for that version and/or may include the updates provided by that version.
Reply 13 of 14, by Necromancist
It's not the game that won't start; it's the setup file.
I might have an idea to what's wrong, though. AC was made when Windows 16-bit were still in use, so 32-bit might have some problems... is there some way to convert it to 32-bit?
