First post, by Quake161
I used dosbox and did everything properly, yet everytime i try to play it, it keeps saying that it is a windows NT game, and it doesnt play it
Reply 3 of 4, by sam767
To Run Mortal Kombat Trilogy on windows xp you Need A patch for windows XP However, it makes it Sloppy Somehow and JOYPAD needs some 3RD party programs to play with , i Would Highly Recommend to run it under DOSBox 0.72 Since MKT is Dos Game Primarily OR you can have it under Windows 95 through Virtual PC
Reply 4 of 4, by wd
Rank DOSBox Author
DOSBox Author
There should be dos files for mktrilogy as well, read the instructions
supplied with the game/installer.
But it might not work in the last dosbox release, so you're better off
with the windows version.
