First post, by eniwetok
- Newbie
The version of The 7th Guest I have contains the original game files as ISOs but also some additional files. I'm under the assumption that it was originally a MS-DOS game and Trilobyte made some attempt to make it work with WIN95... 98... and even NT. Here's what the notes say:
Beta player for The 7th Guest for Windows 95/98/NT […]
The files included are:
N_CRED01.VDX
N_CRED02.VDX
N_CRED03.VDX
N_CRED04.VDX
TRILOGO.VDX (optional)
Vielogo.vdx (optional)
mss32.dll
v32tng.exeTo install:
* Extract the files to your 7th Guest directory
* Run v32tng.exeNote: To toggle between windowed/full screen modes
press both the ALT key and ENTER key at the same time
and release (ALT-ENTER).DISCLAIMER: The DirectX player for the 7th Guest is a beta version, and
thus should be used at your own risk. Trilobyte makes no claim or
warranty to said program. It is not the full version of the game; the
original version is required to play.If you are experiencing problems with the DirectX player, please send an
email, with details about where the game is installed, what kind of machine
you have (Processor, Memory, Operating System (Windows95/98/NT), etc...), and as complete of a description of what happened as you can, to
directx@tbyte.com.
My question is with these later releases of the game can I bypass DOSBOX in installing the main game? Was there a way to do so using Windows? Or do I still need DOSBOX for ALL versions of 7th Guest... and this Beta Player is only an option for playing an already installed game?
Thanks!
