Spell Jammer
First post, by Dark_Lizerd
Does anyone know how to run this game under ANY windows platform????? It is an old DOS game that will not run on any windows, 95 and later... (I will repost later with the error I get....)
Reply 1 of 1, by Nicht Sehr Gut
Originally posted by Dark_Lizerd Does anyone know how to run this game under ANY windows platform?????
Works ok for me. It does seem to be picky about it's AdLib/FM music support.
If you run it with VDMSound you'll need to use the ADVANCED option on your VLP shortcut and choose the early "SoundBlaster Pro" option instead of "SoundBlaster 16" to get the AdLib/FM music working. If you choose:
G) LAPC Music, SoundBlaster Pro Sound Effects
You can keep the SoundBlaster16 setting and you'll get MIDI/MT32 for music instead.
If you can't get it running in XP, you can always try running it in DosBox. As always, be sure and read the REAME that comes with it.
