First post, by Bambo
F1 '97 from Bizarre Creations/Psygonis works nice under Windows XP in D3D mode.
But I'd like to play it with dgvoodoo in glide-mode because of the better resolution I could "hack" in.
I applied the official Voodoo-Patch from the developers and use dgvoodoo 1.40.
Anyway: The 3DFX Version works in the menu but when I start a race it insteat opens a (glitched) driver selection, cycles through the drivers endlessly and refuses any further input (In D3D there is one more menu, when you select "start race" and then you get to the track).
My dgVoodoo settings are default exept for the resolution (1600x1200) and bit deph (32)
Is this a typical problem? And how do I fix it?
I discovered, that the game actually works in the Arcade mode. Still the same bug in Simulation mode...
The Game looks sooo much better with glide. D3D is totally ugly in comparison...
