First post, by heroes2
i found a fix for using heroes of might and magic 2 on a 64 bit computer. for those of you with windows 64bit you will get an error saying this game isn't compatable. after searching online for hours i found a threat that was i was bearly able to understand.
but this is the fix. after mounting the image, explore the cd and go to the "wing" folder and take the wing32.dll and place it in your windows system32 folder and in the syswow64 folder. and boom started right up.. very frustrating after going days looking for emulators and windows compatability problems.. fyi changing the compatability to 95 does not fix this problem.
