First post, by filipetolhuizen
- Oldbie
I'm pretty sure this happens because of very fast systems, but is there a fix for this? It's impossible to finish some races this way.
try vysnc
try a slowdown util like moslow
I created a custom profile for Carma2 using nHancer with every eye candy at maximum and no speed optimizations, same with dgvoodoo. This helped Carma2 a lot, but the thing is that Carma1 runs in software mode (the Windows version) and the dos versions are too unstable.
wrote:I'm pretty sure this happens because of very fast systems, but is there a fix for this? It's impossible to finish some races this way.
Disable the L1 cache or L2 cache in our system BIOS [if it allows you too] most "real" motherboards will. 😀
